Ir para o conteúdo principal
Trio AXS 3G Battery Replacement
O que você precisa
    1. Trio AXS 3G Battery Replacement, Back Case: passo 1, imagem 1 %32
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Pergunte ao FixBot
      Comentar
    2. Trio AXS 3G Battery Replacement: passo 2, imagem 1 %32 Trio AXS 3G Battery Replacement: passo 2, imagem 2 %32
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Pergunte ao FixBot
      Comentar
    3. Trio AXS 3G Battery Replacement: passo 3, imagem 1 %32
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Pergunte ao FixBot
      Comentar
    1. Trio AXS 3G Battery Replacement, Battery: passo 4, imagem 1 %32
      • The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
      Pergunte ao FixBot
      Comentar
    2. Trio AXS 3G Battery Replacement: passo 5, imagem 1 %32
      • Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
      Pergunte ao FixBot
      Comentar
    3. Trio AXS 3G Battery Replacement: passo 6, imagem 1 %32
      Ferramenta utilizada neste passo:
      Plastic Cards
      $2.99
      • Use the plastic card to pry the battery away from the device.
      • The battery is attached to the tablet by glue.
      Pergunte ao FixBot
      Comentar
    4. Trio AXS 3G Battery Replacement: passo 7, imagem 1 %32
      • Peel off the battery from the device to completely remove it.
      Pergunte ao FixBot
      Comentar
Conclusão
2Comentários do guia
where can i buy a battery replacement? can it work without a battery?
millie abanilla - Responder Compartilhar
where can you buy a replacement battery
J W - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 39
Ao todo: 1,650
