Ir para o conteúdo principal
Trek 820 Handlebars Replacement
O que você precisa
    1. Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, imagem 1 %32 Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, imagem 2 %32
      • Use a 3/16" Allen Wrench to remove the silver cap.
      Pergunte ao FixBot
      Comentar
    2. Trek 820 Handlebars Replacement: passo 2, imagem 1 %32
      • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
      Pergunte ao FixBot
      Comentar
    3. Trek 820 Handlebars Replacement: passo 3, imagem 1 %32 Trek 820 Handlebars Replacement: passo 3, imagem 2 %32
      • Remove the handlebar by lifting vertically away from the frame.
      • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
      Pergunte ao FixBot
      Comentar
    4. Trek 820 Handlebars Replacement: passo 4, imagem 1 %32 Trek 820 Handlebars Replacement: passo 4, imagem 2 %32
      • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
      • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
      Pergunte ao FixBot
      Comentar
    5. Trek 820 Handlebars Replacement: passo 5, imagem 1 %32
      • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
      • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
      • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 1-1, Propen Fall 2012 Membro de Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Membros
Autoria de 16 guias
1Comentário do guia
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 69
Ao todo: 6,901
