Ir para o conteúdo principal
Toshiba Thrive Battery Replacement
    1. Toshiba Thrive Battery Replacement, Back Cover: passo 1, imagem 1 %32
      • Make sure the lock switch for the back cover is unlocked.
      • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
      Pergunte ao FixBot
      Comentar
    2. Toshiba Thrive Battery Replacement: passo 2, imagem 1 %32 Toshiba Thrive Battery Replacement: passo 2, imagem 2 %32
      • Remove back cover by prying away from the Thrive.
      • The easiest place to pry from is one of the two speakers.
      Pergunte ao FixBot
      Comentar
    3. Toshiba Thrive Battery Replacement: passo 3, imagem 1 %32
      • To remove the battery, make sure the lock switch is in the unlocked position.
      • The battery is unlocked when the switch is slid to the unlocked position.
      Pergunte ao FixBot
      Comentar
    4. Toshiba Thrive Battery Replacement: passo 4, imagem 1 %32 Toshiba Thrive Battery Replacement: passo 4, imagem 2 %32 Toshiba Thrive Battery Replacement: passo 4, imagem 3 %32
      • Slide the battery switch release to the right.
      • While holding the switch in place, lift up the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
Kason
Membro desde: 09/22/14
1.120 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 10-1, Brown Fall 2014 Membro de USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Membros
Autoria de 12 guias
1Comentário do guia
You should give links on where we can buy the parts that need to be replaced.
Meggie Guerrer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 43
Ao todo: 2,680
