Ir para o conteúdo principal
Toshiba Satellite S50-B Cooling Fan Replacement
O que você precisa
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite S50-B Cooling Fan Replacement, Battery: passo 1, imagem 2 %32
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite S50-B Cooling Fan Replacement: passo 2, imagem 2 %32
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: passo 3, imagem 2 %32 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: passo 3, imagem 3 %32
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite S50-B Cooling Fan Replacement: passo 4, imagem 2 %32 Toshiba Satellite S50-B Cooling Fan Replacement: passo 4, imagem 3 %32
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
Conclusão
Uma outra pessoa concluiu este guia.
diana calvo
Membro desde: 10/17/17
144 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 19
Duração total: 1,544
