Ir para o conteúdo principal
Toshiba Satellite P55-A5312 CD Drive Replacement
O que você precisa
  1. Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: passo 1, imagem 1 %32 Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: passo 1, imagem 2 %32
  2. Toshiba Satellite P55-A5312 CD Drive Replacement: passo 2, imagem 1 %32
    • Locate the CD drive at the lower right hand corner of the laptop.
    • Unscrew any screws that are holding the drive in place. However, there should only be one. The other screws holding the drive in place are also responsible for holding the bottom casing.
  3. Toshiba Satellite P55-A5312 CD Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite P55-A5312 CD Drive Replacement: passo 3, imagem 2 %32
    • Carefully remove the CD drive by pulling it from its connection to the motherboard.
    • Replace it by inserting a new CD drive and replacing any screws you have removed.
Conclusão
ohatae
Membro desde: 01/25/17
294 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-1, Banghart Winter 2017 Membro de Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 774
