Ir para o conteúdo principal
Toshiba Satellite P55-A5312 Battery Replacement
O que você precisa
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite P55-A5312 Battery Replacement, Battery: passo 1, imagem 2 %32
  2. Toshiba Satellite P55-A5312 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite P55-A5312 Battery Replacement: passo 2, imagem 2 %32
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: passo 3, imagem 1 %32
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: passo 4, imagem 1 %32
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop after it has been completely disconnected.
Conclusão
5 outras pessoas executaram este guia.
ohatae
Membro desde: 01/25/17
294 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-1, Banghart Winter 2017 Membro de Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
Membros da 3
Autoria de 6 guias
Um comentário
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 26
Duração total: 5,977
