Ir para o conteúdo principal
Toshiba Satellite L675D-S7016 Battery Replacement
  1. Toshiba Satellite L675D-S7016 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Battery Replacement: passo 2, imagem 1 %32
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite L675D-S7016 Battery Replacement: passo 3, imagem 2 %32 Toshiba Satellite L675D-S7016 Battery Replacement: passo 3, imagem 3 %32
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
Conclusão
To reassemble your device, follow the steps in reverse order.
Uma outra pessoa concluiu este guia.
Equipe
UC Davis, Team 2-2, Oliver Fall 2016 Membro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membros
Autoria de 10 guias
2Comentários do guia
Where would I purchase a battery for a Toshiba L675 laptop? Price?
mford811 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Ao todo: 682
