Ir para o conteúdo principal
Toshiba Satellite L55W-C5256 Speaker Replacement
O que você precisa
  1. Toshiba Satellite L55W-C5256 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 3, imagem 1 %32
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 4, imagem 1 %32
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 5, imagem 1 %32
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 6, imagem 1 %32
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 Speaker Replacement, CPU Heatsink: passo 7, imagem 1 %32
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 8, imagem 1 %32
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 9, imagem 1 %32 Toshiba Satellite L55W-C5256 Speaker Replacement: passo 9, imagem 2 %32 Toshiba Satellite L55W-C5256 Speaker Replacement: passo 9, imagem 3 %32
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
  10. Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: passo 10, imagem 1 %32 Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: passo 10, imagem 2 %32
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the left speaker to the motherboard.
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the right speaker to the motherboard.
  11. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 11, imagem 1 %32 Toshiba Satellite L55W-C5256 Speaker Replacement: passo 11, imagem 2 %32
    • Before touching any component inside your device, ensure you are properly grounded with a static band.
    • Gently unplug the speaker connector cable from the motherboard.
  12. Toshiba Satellite L55W-C5256 Speaker Replacement: passo 12, imagem 1 %32
    • Lift speakers from motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 173
