Ir para o conteúdo principal
Toshiba Satellite L55-A RAM Module Replacement
O que você precisa
  1. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM cover: passo 1, imagem 1 %32
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A RAM Module Replacement: passo 2, imagem 1 %32 Toshiba Satellite L55-A RAM Module Replacement: passo 2, imagem 2 %32
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: passo 3, imagem 1 %32 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: passo 3, imagem 2 %32 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: passo 3, imagem 3 %32
    • This step shows how to remove a RAM module.
    • Use your fingers to spread the two metal clips securing the edge of the RAM module. This should free the module and cause it to pop up slightly.
    • Pull the RAM module out of its slot and remove it.
  4. Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: passo 4, imagem 1 %32 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: passo 4, imagem 2 %32 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: passo 4, imagem 3 %32
    • This step shows how to insert a RAM module.
    • Insert the replacement RAM at a shallow angle into the RAM slot until the gold contacts are fully socketed.
    • Use your fingers to gently press the RAM module's edges down until both metal clips snap into place.
    • If your laptop will not properly recognize the installed RAM, unseat and reseat the RAM, making sure that all modules are fully locked in place.
Conclusão
Arthur Shi
Membro desde: 01/03/18
282.802 Reputação
Autoria de 587 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.465 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 241
