Ir para o conteúdo principal
Toshiba Satellite C655D-S5200 LCD Replacement
O que você precisa
  1. Toshiba Satellite C655D-S5200 LCD Replacement, LCD: passo 1, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement, LCD: passo 1, imagem 2 %32 Toshiba Satellite C655D-S5200 LCD Replacement, LCD: passo 1, imagem 3 %32
    • Here is the Toshiba Satellite C655D-S5200
    • Open the laptop with the LCD facing forward. There are four rubber caps, one in each corner
    • Removing the plugs reveal the Phillips screws
  2. Toshiba Satellite C655D-S5200 LCD Replacement: passo 2, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 2, imagem 2 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 2, imagem 3 %32
    • Remove all four screws, tow on top left and right corner
    • One on the bottom left corner
    • and the bottom right corner.
    • Here are the four M3x5mm screws
  3. Toshiba Satellite C655D-S5200 LCD Replacement: passo 3, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 3, imagem 2 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool, or similar to pop the bezel of the LCD assembly
    • Continue to slide the tool all the way across the top
    • Once the bezel has been released from the tabs, it can be further released be applying some gently manual pulling
  4. Toshiba Satellite C655D-S5200 LCD Replacement: passo 4, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 4, imagem 2 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 4, imagem 3 %32
    • Continue to pull gently on the sides
    • and finally on the bottom.
    • With all the tabs released the bezel can now be removed.
  5. Toshiba Satellite C655D-S5200 LCD Replacement: passo 5, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 5, imagem 2 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 5, imagem 3 %32
    • Here is the LCD assembly without the bezel
    • Remove the Phillips screw that connects the LCD frame to the back cover. This is the left one
    • Remove the right one as well
  6. Toshiba Satellite C655D-S5200 LCD Replacement: passo 6, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 6, imagem 2 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 6, imagem 3 %32
    • The LCD can now be moved forward and away from the rear cover
    • There are three screws on either side that hold the panel to the frame. Remove those
    • Here are the three M2x4 screws
  7. Toshiba Satellite C655D-S5200 LCD Replacement: passo 7, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 7, imagem 2 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 7, imagem 3 %32
    • Remove the three Phillips screws on the right side as well.
    • with the screws removed the panel can now be moved out of the LCD frame. The LCD is still connected by the display cable.
    • The display cable is secured to the connector with some clear adhesive. Remove this frist
  8. Toshiba Satellite C655D-S5200 LCD Replacement: passo 8, imagem 1 %32 Toshiba Satellite C655D-S5200 LCD Replacement: passo 8, imagem 2 %32
    • Remove the display cable carefully.
    • With the display cable disconnected, the LCD can now be removed and replaced.
Conclusão
Uma outra pessoa concluiu este guia.
oldturkey03
Membro desde: 09/29/10
813.552 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
45 Membros
Autoria de 702 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 1,621
