Ir para o conteúdo principal
Toshiba Satellite C55D-A5108 Heat Sink Replacement
O que você precisa
  1. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Heat Sink Replacement: passo 2, imagem 1 %32
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Heat Sink Replacement: passo 3, imagem 1 %32
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Heat Sink Replacement: passo 5, imagem 1 %32
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: passo 6, imagem 1 %32 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: passo 6, imagem 2 %32 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: passo 6, imagem 3 %32
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: passo 7, imagem 1 %32 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: passo 7, imagem 2 %32
    • Remove the four Phillips #0 screws from each corner of the heat sink.
    • Gently lift the heat sink out of the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Smith
Membro desde: 10/25/19
187 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 322
