Ir para o conteúdo principal
Toshiba Satellite C55-B5200 RAM Replacement
O que você precisa
  1. Toshiba Satellite C55-B5200 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 RAM Replacement: passo 2, imagem 1 %32
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 RAM Replacement, RAM: passo 3, imagem 1 %32
    • Flex the metal retaining clips on the side of the RAM away from one another.
    • If done correctly, the RAM will pop out of its lock.
  4. Toshiba Satellite C55-B5200 RAM Replacement: passo 4, imagem 1 %32
    • Pull the RAM out of the socket to remove.
Conclusão
3 outras pessoas executaram este guia.
Pablo Andrade
Membro desde: 02/14/18
1.081 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S3-G1, Nance Spring 2018 Membro de USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Membros
Autoria de 22 guias
Um comentário
So the complete bottom panel doesn’t need to be removed to access the memory? The bottom panel that is held in place by another 8 screws?
Andrew Kling - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 52
Ao todo: 1,355
