Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
A worn-out belt is not strong enough to open or close disc tray. Belt might be broken.
O que você precisa
Five identical screws: three in back, one in each of left and right sides. Cover lifts away. One may call it 'top cover'.
Disc tray being open/extended-out is a precondition to access its drive belt.
Use a stick to depress optical deck and unclamp spindle. As optical deck lowers, disc tray juts. Pull or push tray toward its out & open position.
