Ir para o conteúdo principal
Introdução
A worn-out belt is not strong enough to open or close disc tray. Belt might be broken.
Ferramentas
Peças
  1. Five identical screws: three in back, one in each of left and right sides. Cover lifts away.  One may call it 'top cover'.
    • Five identical screws: three in back, one in each of left and right sides. Cover lifts away. One may call it 'top cover'.
  2. Disc tray being open/extended-out is a precondition to access its drive belt. Use a stick to depress optical deck and unclamp spindle.  As optical deck lowers, disc tray juts.  Pull or push tray toward its out & open position.
    • Disc tray being open/extended-out is a precondition to access its drive belt.
    • Use a stick to depress optical deck and unclamp spindle. As optical deck lowers, disc tray juts. Pull or push tray toward its out & open position.
  3. Replace tray/drive belt.
    • Replace tray/drive belt.
Conclusão
unsubstantiated
Membro desde: 07/06/2016
976 Reputação
4 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 222
