Ir para o conteúdo principal
Toshiba Portege R705-P35 RAM Replacement
O que você precisa
  1. Toshiba Portege R705-P35 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 RAM Replacement: passo 2, imagem 1 %32
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 RAM Replacement: passo 3, imagem 1 %32 Toshiba Portege R705-P35 RAM Replacement: passo 3, imagem 2 %32
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 RAM Replacement, RAM Plate: passo 4, imagem 1 %32 Toshiba Portege R705-P35 RAM Replacement, RAM Plate: passo 4, imagem 2 %32 Toshiba Portege R705-P35 RAM Replacement, RAM Plate: passo 4, imagem 3 %32
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 RAM Replacement, RAM: passo 5, imagem 1 %32 Toshiba Portege R705-P35 RAM Replacement, RAM: passo 5, imagem 2 %32
    • Using a spudger or your fingers, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise.
    • Repeat this procedure with the other metal rod on the opposite side of the RAM stick.
  6. Toshiba Portege R705-P35 RAM Replacement: passo 6, imagem 1 %32 Toshiba Portege R705-P35 RAM Replacement: passo 6, imagem 2 %32
    • Once the RAM stick pops out to an angle, pull it outward.
Conclusão
Kathryn Hockenbury
Membro desde: 03/23/22
833 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team 1-4, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-4, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G4
Membros da 3
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 26
Duração total: 206
