Ir para o conteúdo principal
Toshiba Portege R705-P35 Battery Replacement
  1. Toshiba Portege R705-P35 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 Battery Replacement: passo 2, imagem 1 %32
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 Battery Replacement: passo 3, imagem 1 %32 Toshiba Portege R705-P35 Battery Replacement: passo 3, imagem 2 %32
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
Conclusão
Equipe
UMass Dartmouth, Team 1-4, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-4, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G4
Membros da 3
Autoria de 24 guias
Um comentário
My battery can't resist more than 15 min
massilia.10 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 14
Duração total: 347
