Ir para o conteúdo principal
Toshiba Portege R705-P35 Back Plate Replacement
O que você precisa
  1. Toshiba Portege R705-P35 Back Plate Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 Back Plate Replacement: passo 2, imagem 1 %32
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 Back Plate Replacement: passo 3, imagem 1 %32 Toshiba Portege R705-P35 Back Plate Replacement: passo 3, imagem 2 %32
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 Back Plate Replacement, RAM Plate: passo 4, imagem 1 %32 Toshiba Portege R705-P35 Back Plate Replacement, RAM Plate: passo 4, imagem 2 %32 Toshiba Portege R705-P35 Back Plate Replacement, RAM Plate: passo 4, imagem 3 %32
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 Back Plate Replacement, Hard Drive Plate: passo 5, imagem 1 %32
    • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
  6. Toshiba Portege R705-P35 Back Plate Replacement: passo 6, imagem 1 %32 Toshiba Portege R705-P35 Back Plate Replacement: passo 6, imagem 2 %32
    • Use your hands to remove the hard drive plate from the laptop.
  7. Toshiba Portege R705-P35 Back Plate Replacement, Back Plate: passo 7, imagem 1 %32
    • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
  8. Toshiba Portege R705-P35 Back Plate Replacement: passo 8, imagem 1 %32 Toshiba Portege R705-P35 Back Plate Replacement: passo 8, imagem 2 %32
    • Lift and remove the small plate from the laptop.
  9. Toshiba Portege R705-P35 Back Plate Replacement: passo 9, imagem 1 %32
    • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
    • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
  10. Toshiba Portege R705-P35 Back Plate Replacement: passo 10, imagem 1 %32 Toshiba Portege R705-P35 Back Plate Replacement: passo 10, imagem 2 %32
    • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
Conclusão
Kathryn Hockenbury
Membro desde: 03/23/22
833 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team 1-4, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-4, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G4
Membros da 3
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 21
Duração total: 236
