Ir para o conteúdo principal
Toshiba Chromebook 2 Motherboard Replacement
O que você precisa
  1. Toshiba Chromebook 2 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Motherboard Replacement: passo 2, imagem 1 %32
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Motherboard Replacement: passo 3, imagem 1 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Motherboard Replacement: passo 4, imagem 1 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Toshiba Chromebook 2 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the 14 Phillips 2.34mm screws using the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the metal plate covering the motherboard by lifting it vertically.
  8. Toshiba Chromebook 2 Motherboard Replacement: passo 8, imagem 1 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 8, imagem 2 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 8, imagem 3 %32
    • Flip up the plastic clamps holding down the 4 ribbon cables connected to the motherboard while gently pulling the ribbon cables from the sockets.
  9. Toshiba Chromebook 2 Motherboard Replacement: passo 9, imagem 1 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 9, imagem 2 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 9, imagem 3 %32
    • Use the spudger to press down on the 2 white port cables, while also pulling each white port cable out of their sockets.
  10. Toshiba Chromebook 2 Motherboard Replacement: passo 10, imagem 1 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 10, imagem 2 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 10, imagem 3 %32
    • Disconnect the motherboard from the 3 remaining cables by pulling the chords out of the sockets.
  11. Toshiba Chromebook 2 Motherboard Replacement: passo 11, imagem 1 %32 Toshiba Chromebook 2 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the motherboard by pulling upward and to the right.
    • Be careful not to damage the ports located on the left side of the motherboard during removal.
Conclusão
Sam Nishi
Membro desde: 10/06/16
485 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-4, Livingston Fall 2016 Membro de Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
4 Membros
Autoria de 11 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 2,974
