Introdução
This guide shows how to remove and replace the two drivetrain V-belts for the Toro Cement Mixer 68009HD.
O que você precisa
Before you begin, press the engine-stop switch to turn off the engine.
Remove the four fasteners securing the engine plate:
Two 14 mm bolts
Two 3/4 inch nuts
Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
Quase terminado!
Conclusão
