Introdução
This guide shows how to remove and replace the driveshaft for the Toro Cement Mixer 68009HD. In order to access the driveshaft, you must first remove the tub.
Warning: The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
O que você precisa
Before you begin, press the engine-stop switch to turn off the engine.
Remove the four fasteners securing the engine plate:
Two 14 mm bolts
Two 3/4 inch nuts
Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
Use a crescent wrench to loosen the two set screws on the pulley.
Reassembly tip: The pulley is keyed to install in only one position.
Use a 4 mm hex key to loosen the set screw securing the lock collar.
There should only be one set screw. If the collar isn't loose, check the second hole for set screws.
