Ir para o conteúdo principal
TomTom Runner LCD Screen Replacement Guide
O que você precisa
  1. TomTom Runner LCD Screen Replacement Guide, Wristband: passo 1, imagem 1 %32
    • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
  2. TomTom Runner LCD Screen Replacement Guide: passo 2, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 2, imagem 2 %32
    • Continue to lift up on the band until the screen of the watch becomes loose from the band.
    • You may need to apply a small amount of force downward on the face of the screen.
    • Continue to pull up on the wristband until it is completely off the watch.
  3. TomTom Runner LCD Screen Replacement Guide, Back Panel: passo 3, imagem 1 %32
    • Grab the watch once it is separated from the wristband.
  4. TomTom Runner LCD Screen Replacement Guide: passo 4, imagem 1 %32
    • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
  5. TomTom Runner LCD Screen Replacement Guide: passo 5, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 5, imagem 2 %32
    • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
    • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
    • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
  6. TomTom Runner LCD Screen Replacement Guide: passo 6, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 6, imagem 2 %32
    • Gently pull the back panel away from the front panel.
    • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
  7. TomTom Runner LCD Screen Replacement Guide: passo 7, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 7, imagem 2 %32
    • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
    • Be gentle with the red and black wires. You do not want them to rip or pop out.
    • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
  8. TomTom Runner LCD Screen Replacement Guide, Front Cover: passo 8, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide, Front Cover: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
    • You will need to be gentle and pull the copper slowly so that it does not rip.
  9. TomTom Runner LCD Screen Replacement Guide: passo 9, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 9, imagem 2 %32
    • Use the bent, metal precision tweezers to remove the thin copper piece from large square silver piece in the Front Casing.
  10. TomTom Runner LCD Screen Replacement Guide: passo 10, imagem 1 %32
    • Remove the two 2.0 mm Torx Head screws with the T5 Torx screwdriver.
  11. TomTom Runner LCD Screen Replacement Guide: passo 11, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 11, imagem 2 %32 TomTom Runner LCD Screen Replacement Guide: passo 11, imagem 3 %32
    • Use your fingers to gently pull the whole green motherboard out of the Front Casing.
    • If you have trouble using your fingers, then use the black Spudger tool.
  12. TomTom Runner LCD Screen Replacement Guide, LCD Screen: passo 12, imagem 1 %32
    • Grab the screen attached to the green motherboard.
  13. TomTom Runner LCD Screen Replacement Guide: passo 13, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 13, imagem 2 %32 TomTom Runner LCD Screen Replacement Guide: passo 13, imagem 3 %32
    • Using the pointed end of the black Spudger tool, gently pry the motherboard away from the screen.
    • The motherboard and screen are very fragile, but the motherboard should pop right off.
    • Once you have the motherboard partially pried off, use your fingers to gently pop it out of the clear, plastic clips holding it in place.
    • Continue to pull the motherboard away from the screen to fully expose the white backing of the screen.
  14. TomTom Runner LCD Screen Replacement Guide: passo 14, imagem 1 %32 TomTom Runner LCD Screen Replacement Guide: passo 14, imagem 2 %32 TomTom Runner LCD Screen Replacement Guide: passo 14, imagem 3 %32
    • Once the white backing of the screen is exposed, carefully flip the two pieces, the motherboard and the screen, over while they are still connected.
    • Look for the small metal piece attached to the motherboard that is wrapped around the front of the screen.
    • Gently slide the screen under and back to free it from the metal piece.
  15. TomTom Runner LCD Screen Replacement Guide: passo 15, imagem 1 %32
    • Once free from the Front Casing and the motherboard, you are ready to replace the screen.
Conclusão
Amber Scarborough
Membro desde: 03/20/17
1.157 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team S8-G6, Bennett Spring 2017 Membro de Texas Tech, Team S8-G6, Bennett Spring 2017
TTU-BENNETT-S17S8G6
4 Membros
Autoria de 15 guias
8Comentários do guia
Who sells the replacement screens? I can’t find them anywhere online. Do I need to contact TomTom directly?
Erin Espinoza - Responder Compartilhar
Please help where can i buy the lcd
hjcouto - Responder Compartilhar
This article is useless unless you know where to buy the replacement screen!!!!
Kel Needham - Responder Compartilhar
this tutorial is without function because there is no sale of replacement screens. unfortunately
fielbicolor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 75
Ao todo: 10,697
