Ir para o conteúdo principal
TomTom One XL Screen Replacement
O que você precisa
  1. TomTom One XL Screen Replacement, Back Panel: passo 1, imagem 1 %32 TomTom One XL Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the 4 .4mm screws on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. TomTom One XL Screen Replacement: passo 2, imagem 1 %32
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
    Pergunte ao FixBot
    Comentar
  3. TomTom One XL Screen Replacement: passo 3, imagem 1 %32
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
    Pergunte ao FixBot
    Comentar
  4. TomTom One XL Screen Replacement: passo 4, imagem 1 %32 TomTom One XL Screen Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
    Pergunte ao FixBot
    Comentar
  5. TomTom One XL Screen Replacement, Screen: passo 5, imagem 1 %32 TomTom One XL Screen Replacement, Screen: passo 5, imagem 2 %32
    • Locate the 4 .4mm screws connecting the circuit board to the front panel.
    • Use the T6 Torx screwdriver and remove the four screws.
    Pergunte ao FixBot
    Comentar
  6. TomTom One XL Screen Replacement: passo 6, imagem 1 %32 TomTom One XL Screen Replacement: passo 6, imagem 2 %32 TomTom One XL Screen Replacement: passo 6, imagem 3 %32
    • Locate the ribbon cable connecting the front panel to the circuit board.
    • Locate the white tab locking the ribbon in place.
    • Using precision tweezers push the left and right side of the tab forward.
    • Gently pull the ribbon to disconnect the circuit board from the front panel.
    • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
    Pergunte ao FixBot
    Comentar
  7. TomTom One XL Screen Replacement: passo 7, imagem 1 %32 TomTom One XL Screen Replacement: passo 7, imagem 2 %32 TomTom One XL Screen Replacement: passo 7, imagem 3 %32
    • Use the palate knife to pry the screen away from the front panel.
    • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
    • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
    Pergunte ao FixBot
    Comentar
Conclusão
DeVhan
Membro desde: 03/11/15
401 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 1,239
