Ir para o conteúdo principal
TomTom One XL Power Button Replacement
O que você precisa
  1. TomTom One XL Power Button Replacement, Back Panel: passo 1, imagem 1 %32 TomTom One XL Power Button Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the 4 .4mm screws on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. TomTom One XL Power Button Replacement: passo 2, imagem 1 %32
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
    Pergunte ao FixBot
    Comentar
  3. TomTom One XL Power Button Replacement: passo 3, imagem 1 %32
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
    Pergunte ao FixBot
    Comentar
  4. TomTom One XL Power Button Replacement: passo 4, imagem 1 %32 TomTom One XL Power Button Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
    Pergunte ao FixBot
    Comentar
  5. TomTom One XL Power Button Replacement, Power Button: passo 5, imagem 1 %32
    • Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
    • The motherboard is connected to the screen assembly via a ribbon wire. After removing the screws, be careful not to damage the wire or the port.
    Pergunte ao FixBot
    Comentar
  6. TomTom One XL Power Button Replacement: passo 6, imagem 1 %32 TomTom One XL Power Button Replacement: passo 6, imagem 2 %32
    • Detach the ribbon wire from it's port on the back of the motherboard.
    Pergunte ao FixBot
    Comentar
  7. TomTom One XL Power Button Replacement: passo 7, imagem 1 %32 TomTom One XL Power Button Replacement: passo 7, imagem 2 %32 TomTom One XL Power Button Replacement: passo 7, imagem 3 %32
    • Now the power button is exposed and any obstructions can be easily removed.
    • If you want to replace the button it can easily be popped out using your hands.
    Pergunte ao FixBot
    Comentar
Conclusão
Jesse
Membro desde: 03/11/15
101 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 2,582
