Ir para o conteúdo principal
Toast Master Blender Button Replacement
O que você precisa
    1. Toast Master Blender Button Replacement, Blender Button: passo 1, imagem 1 %32 Toast Master Blender Button Replacement, Blender Button: passo 1, imagem 2 %32 Toast Master Blender Button Replacement, Blender Button: passo 1, imagem 3 %32
      • Unplug the plug if connected to any outlets.
      • Take off the cap from the blender and turn the appliance upside down.
      • The blender should be standing upward stably.
      Pergunte ao FixBot
      Comentar
    2. Toast Master Blender Button Replacement: passo 2, imagem 1 %32 Toast Master Blender Button Replacement: passo 2, imagem 2 %32 Toast Master Blender Button Replacement: passo 2, imagem 3 %32
      • Use an allen wrench to remove the three screws from the bottom cover.
      Pergunte ao FixBot
      Comentar
    3. Toast Master Blender Button Replacement: passo 3, imagem 1 %32 Toast Master Blender Button Replacement: passo 3, imagem 2 %32 Toast Master Blender Button Replacement: passo 3, imagem 3 %32
      • Take off the black blender stand.
      • Take off three silver screws.
      • Put the screws safely aside.
      Pergunte ao FixBot
      Comentar
    4. Toast Master Blender Button Replacement: passo 4, imagem 1 %32 Toast Master Blender Button Replacement: passo 4, imagem 2 %32 Toast Master Blender Button Replacement: passo 4, imagem 3 %32
      • Use the Allen wrench to remove the three silver screws on the next level of the blender.
      Pergunte ao FixBot
      Comentar
    5. Toast Master Blender Button Replacement: passo 5, imagem 1 %32 Toast Master Blender Button Replacement: passo 5, imagem 2 %32
      • Remove the black cap by lifting it upwards and gently placing it aside.
      • Do not pull hard on the wire as this may cause it to break
      Pergunte ao FixBot
      Comentar
    6. Toast Master Blender Button Replacement: passo 6, imagem 1 %32 Toast Master Blender Button Replacement: passo 6, imagem 2 %32 Toast Master Blender Button Replacement: passo 6, imagem 3 %32
      • Looking into the internal part of the blender, identify the two silver screws near the button and unscrew them with the screwdriver.
      • Carefully remove two silver screws.
      Pergunte ao FixBot
      Comentar
    7. Toast Master Blender Button Replacement: passo 7, imagem 1 %32 Toast Master Blender Button Replacement: passo 7, imagem 2 %32 Toast Master Blender Button Replacement: passo 7, imagem 3 %32
      • Take out the black piece that was attached with the screws and safely place it aside.
      Pergunte ao FixBot
      Comentar
    8. Toast Master Blender Button Replacement: passo 8, imagem 1 %32 Toast Master Blender Button Replacement: passo 8, imagem 2 %32 Toast Master Blender Button Replacement: passo 8, imagem 3 %32
      • Take out the button from the blender.
      • This is the plastic button for Toast Master Blender. If you have a spare button, you can replace it.
      • Make sure that side is facing up and place it back into the original position.
      • The button should have a pointier side that resembles a bunny’s head.
      Pergunte ao FixBot
      Comentar
    9. Toast Master Blender Button Replacement: passo 9, imagem 1 %32
      • Press the button and make sure it has a “click” sound.
      • If the button is still loose, go back to the previous step and recheck that the button is in the correct position.
      Pergunte ao FixBot
      Comentar
    10. Toast Master Blender Button Replacement: passo 10, imagem 1 %32 Toast Master Blender Button Replacement: passo 10, imagem 2 %32 Toast Master Blender Button Replacement: passo 10, imagem 3 %32
      • Reassemble all the parts back, and screw all the screws back to its original place.
      • All the silver screws are the same size.
      • Make sure the black cap separates rotating paddles and wires.
      • There should be no wires wrapped around the rotating blades.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jessica Li
Membro desde: 02/02/24
181 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-8, Andersen Winter 2024 Membro de UC Davis, Team 4-8, Andersen Winter 2024
UCD-ANDERSEN-W24S4G8
2 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 59
Ao todo: 1,230
