Introdução
Thrustmaster sells spare parts through its online store.
You can also contact Thrustmaster technical support to obtain a replacement part if it is not available in your area.
O que você precisa
Unscrew the 4 screws on the front panel.
Unscrew the 3 screws under the cover.
Unscrew the 5 screws under the base.
Take off the top cover from your base by lifting it from the back.
Disconnect the fan connector from the main PCB.
Remove the fan by unscrew 2 screws of the fan.
To reassemble your unit, follow the instructions in reverse order.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
