Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Thomas Ride On Train, use o nosso manual de serviço.
    1. Thomas Ride on Train - System Diagram and Components, Thomas Ride on Train - System Diagram and Components: passo 1, imagem 1 %32
      • System Components
      • When power is applied to the charging connector it activates a relay which disconnects the power to the main circuits.
      • The main powerswitch is under the large yellow lever and simply applies power from the battery to the control board in the console.
      • A multipole switch is used to reverse the direction of the motor
      • An LED in the console flashes with the sound
      • The sound is provided by a loudspeaker in the base
      Pergunte ao FixBot
      Comentar
    2. Thomas Ride on Train - System Diagram and Components: passo 2, imagem 1 %32 Thomas Ride on Train - System Diagram and Components: passo 2, imagem 2 %32
      • Charging Connector
      • The charging connector is on the rear of the train between the buffers
      • My connector is a "old style" connector which is effectively a phono, the new style is a more conventional power connector
      Pergunte ao FixBot
      Comentar
    3. Thomas Ride on Train - System Diagram and Components: passo 3, imagem 1 %32
      • Power Switch and Charging Relay Board
      Pergunte ao FixBot
      Comentar
    4. Thomas Ride on Train - System Diagram and Components, 6v Sealed Lead Acid Battery: passo 4, imagem 1 %32
      • This battery has been replaced, the originals attach via a clip
      • Note the fuse on the positive connector
      Pergunte ao FixBot
      Comentar
    5. Thomas Ride on Train - System Diagram and Components, Reversing switch and LED: passo 5, imagem 1 %32
      • This switch is controlled by the level on the console and switches the polarity of the motor connectors.
      • Middle position is off, the other two positions are forward and backwards
      • If you are replacing the LED don't forget that the polarity of the wires is important
      Pergunte ao FixBot
      Comentar
    6. Thomas Ride on Train - System Diagram and Components, Control board: passo 6, imagem 1 %32
      • Has three switches to activate the music and connectors leading off to the motor, speaker, LED and battery
      Pergunte ao FixBot
      Comentar
    7. Thomas Ride on Train - System Diagram and Components, Loudspeaker: passo 7, imagem 1 %32
      • This is a 16ohm speaker
      Pergunte ao FixBot
      Comentar
    8. Thomas Ride on Train - System Diagram and Components, Motor: passo 8, imagem 1 %32
      • 6v electric motor with capacitor for noise and spark suppressor wired across the terminals
      Pergunte ao FixBot
      Comentar
10Comentários do guia
sound their but it's stoped moving
Leona - Responder Compartilhar
If you've got sound but no movement then the most likely cause is the battery is discharged or defective. If you have a multimeter you could check the voltage on the battery.
If may also be a motor / mechanical issue. With the power disconnected you should be able to rotate the wheels but it won't spin freely as there is a gearbox.
Andy from Workshopshed - Responder Compartilhar
Movement but no sound? Been charged
Shiipwreck Flynn - Responder Compartilhar
That could be a problem with the sound board which lives inside the steering wheel. It's quite a challenge to get to that which is what caused me to write the guide in the first place. I had to clean the switches on that board to get mine to work.
Alternatively could be a loose or broken wire on the speaker which is down in the base, one of the first things you get too when stripping it down.
What do I clean it with? Just polish? Had a look. Wires look fine so im confused lol
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 19
Últimos 30 dias: 74
Ao todo: 9,066
