Ir para o conteúdo principal
ThinkPad Edge E31 RAM Replacement
O que você precisa
  1. ThinkPad Edge E31 RAM  Replacement, Battery: passo 1, imagem 1 %32
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    Pergunte ao FixBot
    Comentar
  2. ThinkPad Edge E31 RAM  Replacement: passo 2, imagem 1 %32
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    Pergunte ao FixBot
    Comentar
  3. ThinkPad Edge E31 RAM  Replacement, ThinkPad Edge E31 Underside Disassembly: passo 3, imagem 1 %32
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    Pergunte ao FixBot
    Comentar
  4. ThinkPad Edge E31 RAM  Replacement, RAM: passo 4, imagem 1 %32
    • The RAM slots are next to the hard drive to the right of the exposed laptop.
    • There are 2 flexible brackets holding each RAM chip in place is.
    • Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
    Pergunte ao FixBot
    Comentar
  5. ThinkPad Edge E31 RAM  Replacement: passo 5, imagem 1 %32
    • Once freed from the brackets, the RAM can now be easily pulled out of its slot.
    Pergunte ao FixBot
    Comentar
  6. ThinkPad Edge E31 RAM  Replacement: passo 6, imagem 1 %32
    • If your laptop has a second RAM chip in the available slot, repeat the previous 2 steps to remove it.
    • If you are going to be putting 2 RAM chips in your laptop, ensure that they are matching makes and models. This will ensure that you avoid any potential issues that may occur by mixing and matching RAM chips.
    Pergunte ao FixBot
    Comentar
Conclusão
Riley
Membro desde: 03/19/17
601 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 549
