Introdução
This step by step guide will lead you through the process of replacing or upgrading your ThinkPad Edge 13 E31's RAM. Each of the two slots can take up to 4GB of DDR3 RAM.
O que você precisa
There are two two locks for the battery, one on the left and one on the right.
Slide the left lock to the left.
Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
The RAM slots are next to the hard drive to the right of the exposed laptop.
There are 2 flexible brackets holding each RAM chip in place is.
Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
