Ir para o conteúdo principal
The Claw Bottom Cover Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. The Claw Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Place The Claw in upright position with controls facing you.
  2. The Claw Bottom Cover Replacement: passo 2, imagem 1 %32
    • Gently flip The Claw machine upside down with the controls facing you.
  3. The Claw Bottom Cover Replacement: passo 3, imagem 1 %32
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
  4. The Claw Bottom Cover Replacement: passo 4, imagem 1 %32 The Claw Bottom Cover Replacement: passo 4, imagem 2 %32
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
  5. The Claw Bottom Cover Replacement: passo 5, imagem 1 %32
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: Como soldar e dessoldar contatos.
Conclusão
Alain Pierre
Membro desde: 03/22/16
1.188 Reputação
Autoria de 9 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 127
