Ir para o conteúdo principal
Texas Instruments TI-92 Batteries Replacement
O que você precisa
  1. Texas Instruments TI-92 Batteries Replacement, Back Cover: passo 1, imagem 1 %32 Texas Instruments TI-92 Batteries Replacement, Back Cover: passo 1, imagem 2 %32 Texas Instruments TI-92 Batteries Replacement, Back Cover: passo 1, imagem 3 %32
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
    Pergunte ao FixBot
    Comentar
  2. Texas Instruments TI-92 Batteries Replacement: passo 2, imagem 1 %32 Texas Instruments TI-92 Batteries Replacement: passo 2, imagem 2 %32
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
    Pergunte ao FixBot
    Comentar
  3. Texas Instruments TI-92 Batteries Replacement: passo 3, imagem 1 %32 Texas Instruments TI-92 Batteries Replacement: passo 3, imagem 2 %32
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
    Pergunte ao FixBot
    Comentar
  4. Texas Instruments TI-92 Batteries Replacement, Batteries: passo 4, imagem 1 %32 Texas Instruments TI-92 Batteries Replacement, Batteries: passo 4, imagem 2 %32 Texas Instruments TI-92 Batteries Replacement, Batteries: passo 4, imagem 3 %32
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 15-51, Garner Spring 2010 Membro de Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 22
Últimos 30 dias: 70
Ao todo: 8,055
