Ir para o conteúdo principal
Texas Instruments TI-5130 Printer Unit Replacement
O que você precisa
  1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: passo 1, imagem 1 %32 Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: passo 1, imagem 2 %32
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Texas Instruments TI-5130 Printer Unit  Replacement: passo 2, imagem 1 %32
    • Flip the calculator back over and remove the top cover.
    Pergunte ao FixBot
    Comentar
  3. Texas Instruments TI-5130 Printer Unit  Replacement: passo 3, imagem 1 %32
    • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Texas Instruments TI-5130 Printer Unit  Replacement: passo 4, imagem 1 %32
    • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
    Pergunte ao FixBot
    Comentar
  5. Texas Instruments TI-5130 Printer Unit  Replacement: passo 5, imagem 1 %32 Texas Instruments TI-5130 Printer Unit  Replacement: passo 5, imagem 2 %32
    • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
    • Remove the printer unit by lifting it up.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Shannon Perkins
Membro desde: 09/17/15
652 Reputação
Autoria de 3 guias
Equipe
2Comentários do guia
wehre did you buy the replacement printer
Tino ullrich - Responder Compartilhar
what sources are there for TI-5130 printer unit?
Norman Todd - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 37
Ao todo: 2,964
