Ir para o conteúdo principal
Texas Instruments TI-30X IIS Solar Panel Replacement
O que você precisa
  1. Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: passo 1, imagem 1 %32 Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: passo 1, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four 5 mm screws securing the back panel.
  2. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 2, imagem 1 %32
    • Wedge an opening tool in the gap between the front and back panel, then gently pry until the tabs release.
  3. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 3, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two 3 mm screws securing the motherboard.
  4. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 4, imagem 1 %32
    • Desoldering and soldering presents a potential for device damage. Always solder/desolder in well-ventilated environments and with care not to burn yourself.
    • Desolder the positive the negative terminals on the motherboard.
  5. Texas Instruments TI-30X IIS Solar Panel Replacement: passo 5, imagem 1 %32 Texas Instruments TI-30X IIS Solar Panel Replacement: passo 5, imagem 2 %32
    • Gently lift up the front of the motherboard, at the top of the calculator.
    • Desolder the positive and negative terminals on the solar panel
    • Use the tip of a spudger to "walk" the solar panel out of its housing, by pushing it down through the two cutouts until it slides out of the bottom.
    • Remove the solar panel.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 32
Duração total: 651
