Introdução
This guide will require a new solar panel part, as well as some soldering. If you're not sure how to solder, see iFixit's soldering guide.
O que você precisa
Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
Lift the metal plate from the battery and set it to the side.
Put the new CR2032 battery in. Never insert a different type of battery!
Reverse the steps 2 and 1.
Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
Carefully pull the solar panel away from the calculator, as shown to the left.
