Ir para o conteúdo principal
Texas Instruments TI-30 XS Multiview Solar Panel Replacement
O que você precisa
  1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: passo 1, imagem 1 %32 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: passo 1, imagem 2 %32
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
  2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: passo 2, imagem 1 %32
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: passo 3, imagem 1 %32
    • Use the spudger (or fingernail) to lift the battery from the black holder.
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Make sure the positive side of your CR2032 is facing up.
    • Reverse the steps 2 and 1.
  4. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: passo 5, imagem 1 %32
    • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
  5. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: passo 6, imagem 1 %32
    • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
    • Carefully pull the solar panel away from the calculator, as shown to the left.
  6. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: passo 7, imagem 1 %32
    • The capacitor might not be discharged. Proceed with caution.
    • Unsolder the three wires from the motherboard.
    • Unsoldering help can be found here.
    • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
Conclusão
Equipe
Cal Poly, Team 11-2, Forte Fall 2015 Membro de Cal Poly, Team 11-2, Forte Fall 2015
CPSU-FORTE-F15S11G2
4 Membros
Autoria de 9 guias
1Comentário do guia
Do you know where I could get a replacement solar panel for the calculator?
Josh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 76
Ao todo: 2,949
