Ir para o conteúdo principal
Tefal Turbo Pro 400 Steam Iron Disassembly
O que você precisa
  1. Tefal Turbo Pro 400 Steam Iron Disassembly, Rear cover removal - 1: passo 1, imagem 1 %32
    • Remove a Torx security screw from the rear of the iron.
  2. Tefal Turbo Pro 400 Steam Iron Disassembly, Rear cover removal - 2: passo 2, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Rear cover removal - 2: passo 2, imagem 2 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Rear cover removal - 2: passo 2, imagem 3 %32
    • Using a nylon spudger, or with care a small flat screwdriver, ease the rear cover away from the main body of the iron on both sides, starting at the top near the cable entry.
    • Once the rear cover starts to come away you can increase the gap created by inserting the spudger a little further down.
    • Note the tab on the rear cover shown in the 3rd photo which was holding the rear cover in place. On reassembly this can't be re-inserted without lifting the top cover (see Step 7 later).
    Thanks for nice pictures and sequence for disassembly, but for rear cover removal is better another method.
    First use small flat screwdriver at the bottom and slow press plastic holders near edges of iron. Rear cover can be pulled to the rear and up after bottom holder's locks are released.
    Paolo - Responder
  3. Tefal Turbo Pro 400 Steam Iron Disassembly, Releasing the mains cord: passo 3, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Releasing the mains cord: passo 3, imagem 2 %32
    • You can now remove the mains cord inlet half-ball from its socket and the cord from the strain relief S-bend.
    • If all you need to do is replace the mains cord you can now do so. Ensure you use heat-resistant cable of the same current carrying capacity.
  4. Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the steam buttons: passo 4, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the steam buttons: passo 4, imagem 2 %32
    • Remove the two steam buttons. These just pull out. To get the first one out, press the other so you can grip the one you're trying to remove.
  5. Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the anti-calc valve: passo 5, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the anti-calc valve: passo 5, imagem 2 %32
    • Remove the anti-calc valve in front of the steam buttons.
  6. Tefal Turbo Pro 400 Steam Iron Disassembly, Remove the top cover - 1: passo 6, imagem 1 %32
    • Remove a Torx security screw which was hidden by the steam buttons.
  7. Tefal Turbo Pro 400 Steam Iron Disassembly, Remove the top cover - 2: passo 7, imagem 1 %32
    • Whilst lifting the rear of the top cover with one hand, release two clips, one each side, which retain it.
    • If you went no further than removing the rear cover and want to replace it, you have to perform this step before you can re-insert its tabs.
  8. Tefal Turbo Pro 400 Steam Iron Disassembly, Remove the top cover - 3: passo 8, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Remove the top cover - 3: passo 8, imagem 2 %32
    • Push the top cover in the direction shown by the arrow in order to release the four tabs shown in the second photo.
    • List the top cover off.
  9. Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the iron top: passo 9, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the iron top: passo 9, imagem 2 %32
    • Remove a Torx security screw from near the front of the iron, revealed by the removal of the top cover.
    • Lift off the top of the iron.
  10. Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the plastic base - 1: passo 10, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the plastic base - 1: passo 10, imagem 2 %32
    • Disconnect a linkage between the temperature control mechanism and the steam valve. You can do this by pressing one part with a small flat-blade screwdriver while supporting the other underneath. Take care as these small plastic parts could easily be broken.
    • A linkage on the other side operated by the automatic steam control simply lifts off.
    • Slide both mechanisms back as far as they will go.
    • Note that on reassembly both mechanisms and the knobs controlling them must all be in their rear-most positions to ensure they re-connect correctly.
  11. Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the plastic base - 2: passo 11, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the plastic base - 2: passo 11, imagem 2 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Removing the plastic base - 2: passo 11, imagem 3 %32
    • There are 3 twisted metal tabs holding the plastic base to the sole plate assembly. Twist each with pliers to line it up with its slot.
    • You can now lift the plastic base away from the sole plate assembly.
  12. Tefal Turbo Pro 400 Steam Iron Disassembly, Checking the thermostat: passo 12, imagem 1 %32 Tefal Turbo Pro 400 Steam Iron Disassembly, Checking the thermostat: passo 12, imagem 2 %32
    • You can now inspect the thermostat. This comprises a bimetallic strip which opens or closes a pair of contacts. The contacts may need cleaning as a result of ingress of water.
    • You can clean the contacts with switch cleaner fluid (available in an aerosol) and a small piece of fine emery paper. Ensure that the contacts snap open and closed when you apply light pressure to one side or the other of the bimetallic strip.
    • On this iron, perhaps slightly unusually, there is a second pair of normally closed contacts which may have suffered corrosion. If you know what these are for, please leave a comment on this Instructable. My guess is that they are a safety cut-out to prevent overheating and fire if the iron is left standing flat while switched on.
    • Identify the connections to the element and test the resistance between them with a multimeter. It should be around 30 ohms (this iron is rated at 240V 2KW).
Conclusão
20 outras pessoas executaram este guia.
Philip Le Riche
Membro desde: 02/18/14
30.768 Reputação
Autoria de 47 guias
Equipe
Restart Project Membro de Restart Project
Local Repair Groups
Membros da 23
Autoria de 661 guias
4 comentários
THX a lot! I would never have found the screws! :)
BR
Michael
Mik - Responder
Very good guide. The steps were the same on my Tefal Avantis 120.
I believe that you should change your guide. If you remove the top-cover first, you don’t brake the plastic tabs.
Ismaael - Responder
Looks good. I do wish you had specified the size of the security torx. I have a set of bits, but the hole is to small for the sleeve on my driver. I was hoping to find the size to only purchase what I needed. I rather suspect that T-fal would not use a different size for every model iron.
Bruce Nelson - Responder
Unfortunately the short security bits you get in a set are of limited use in many such situations for reasons you’ve discovered. I suggested to iFixit a while back that they develop a hex screwdriver extension with a very thin sleeve but they were unable to come up with a way of making it sufficiently strong whilst as thin as you need. I’m sorry I didn’t record the size of Torx bit, but at the end of the day, a set of long bits or individual screwdrivers is a very worthwhile investment.
Philip Le Riche - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 93
Últimos 30 dias: 312
Duração total: 40,382
