Ir para o conteúdo principal
Teenage Engineering OP-Z Expansion Module Replacement
  1. Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: passo 1, imagem 1 %32 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: passo 1, imagem 2 %32 Teenage Engineering OP-Z Expansion Module Replacement, Back Cover: passo 1, imagem 3 %32
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
    Pergunte ao FixBot
    Comentar
  2. Teenage Engineering OP-Z Expansion Module Replacement: passo 2, imagem 1 %32 Teenage Engineering OP-Z Expansion Module Replacement: passo 2, imagem 2 %32
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
    Pergunte ao FixBot
    Comentar
  3. Teenage Engineering OP-Z Expansion Module Replacement: passo 3, imagem 1 %32
    • Remove the bottom plate including the rubber feet.
    Pergunte ao FixBot
    Comentar
  4. Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: passo 4, imagem 1 %32 Teenage Engineering OP-Z Expansion Module Replacement, Expansion Module: passo 4, imagem 2 %32
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
    Pergunte ao FixBot
    Comentar
  5. Teenage Engineering OP-Z Expansion Module Replacement: passo 5, imagem 1 %32
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
    Pergunte ao FixBot
    Comentar
Conclusão
Tobias Isakeit
Membro desde: 03/31/14
134.397 Reputação
Autoria de 189 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 44
Ao todo: 1,589
