Ir para o conteúdo principal
Teenage Engineering OP-Z Back Cover Replacement
  1. Teenage Engineering OP-Z Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Back Cover Replacement: passo 2, imagem 1 %32 Teenage Engineering OP-Z Back Cover Replacement: passo 2, imagem 2 %32
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Back Cover Replacement: passo 3, imagem 1 %32
    • Remove the bottom plate including the rubber feet.
Conclusão
Tobias Isakeit
Membro desde: 03/31/14
124.281 Reputação
Autoria de 189 guias
Equipe
3 comentários
and uhm where to order the backplate? :/
boombipbass - Responder
Do you not sell the plate anymore?
Jason - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 1,758
