Ir para o conteúdo principal
Teddy Ruxpin Speaker Replacement
O que você precisa
  1. Teddy Ruxpin Speaker Replacement, Battery: passo 1, imagem 1 %32 Teddy Ruxpin Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Speaker Replacement: passo 2, imagem 1 %32
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Speaker Replacement: passo 3, imagem 1 %32
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Speaker Replacement, Arms: passo 4, imagem 1 %32 Teddy Ruxpin Speaker Replacement, Arms: passo 4, imagem 2 %32 Teddy Ruxpin Speaker Replacement, Arms: passo 4, imagem 3 %32
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Speaker Replacement: passo 5, imagem 1 %32
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Speaker Replacement: passo 6, imagem 1 %32 Teddy Ruxpin Speaker Replacement: passo 6, imagem 2 %32 Teddy Ruxpin Speaker Replacement: passo 6, imagem 3 %32
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Speaker Replacement: passo 7, imagem 1 %32 Teddy Ruxpin Speaker Replacement: passo 7, imagem 2 %32
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Speaker Replacement: passo 8, imagem 1 %32 Teddy Ruxpin Speaker Replacement: passo 8, imagem 2 %32
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Speaker Replacement: passo 9, imagem 1 %32
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Speaker Replacement, Housing Cover: passo 10, imagem 1 %32 Teddy Ruxpin Speaker Replacement, Housing Cover: passo 10, imagem 2 %32 Teddy Ruxpin Speaker Replacement, Housing Cover: passo 10, imagem 3 %32
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Speaker Replacement, Speaker: passo 11, imagem 1 %32 Teddy Ruxpin Speaker Replacement, Speaker: passo 11, imagem 2 %32
    • Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
  12. Teddy Ruxpin Speaker Replacement: passo 12, imagem 1 %32
    • Desolder the wire from the speaker and replace.
Conclusão
Uma outra pessoa concluiu este guia.
Jayin Patel
Membro desde: 01/23/20
406 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S18-G5, White Winter 2020 Membro de Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 866
