Introdução
If your Teddy Ruxpin is not turning on you may need to replace the battery. This is a replacement guide for removing the batteries from the Teddy Ruxpin model #17262DS. For this guide, you will need four double AA batteries and a Phillips #2 screwdriver head. This replacement guide should be quick and easy.
O que você precisa
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
