Ir para o conteúdo principal
Teddy Bear Nose Replacement
O que você precisa
  1. Teddy Bear Nose Replacement, Nose: passo 1, imagem 1 %32 Teddy Bear Nose Replacement, Nose: passo 1, imagem 2 %32
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: passo 2, imagem 1 %32 Teddy Bear Nose Replacement: passo 2, imagem 2 %32
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: passo 3, imagem 1 %32
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: passo 4, imagem 1 %32 Teddy Bear Nose Replacement: passo 4, imagem 2 %32
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: passo 5, imagem 1 %32
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: passo 6, imagem 1 %32
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: passo 7, imagem 1 %32
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: passo 8, imagem 1 %32
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: passo 9, imagem 1 %32
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: passo 10, imagem 1 %32 Teddy Bear Nose Replacement: passo 10, imagem 2 %32 Teddy Bear Nose Replacement: passo 10, imagem 3 %32
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: passo 11, imagem 1 %32 Teddy Bear Nose Replacement: passo 11, imagem 2 %32
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
Linha de Chegada
Nazib Khan
Membro desde: 09/28/21
193 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 113
Duração total: 3,817
