Ir para o conteúdo principal
Tara Handle Replacement
    1. Tara Handle Replacement, Handle: passo 1, imagem 1 %32
      • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
      • Use a Tara tool to loosen the jam nuts on either side of the pump.
      • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
      Pergunte ao FixBot
      Comentar
    2. Tara Handle Replacement: passo 2, imagem 1 %32 Tara Handle Replacement: passo 2, imagem 2 %32 Tara Handle Replacement: passo 2, imagem 3 %32
      • Unscrew the lock bolts about half an inch.
      • The bolts do not need to be removed from the base.
      Pergunte ao FixBot
      Comentar
    3. Tara Handle Replacement: passo 3, imagem 1 %32 Tara Handle Replacement: passo 3, imagem 2 %32
      • Pull the plastic bushing and handle straight up out of the pump.
      • If the bushing doesn't come up, loosen the lock bolts further.
      Pergunte ao FixBot
      Comentar
    4. Tara Handle Replacement: passo 4, imagem 1 %32 Tara Handle Replacement: passo 4, imagem 2 %32
      • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
      Pergunte ao FixBot
      Comentar
    5. Tara Handle Replacement: passo 5, imagem 1 %32 Tara Handle Replacement: passo 5, imagem 2 %32 Tara Handle Replacement: passo 5, imagem 3 %32
      • Loosen the jam nut beneath the pump handle using the Tara tool.
      Pergunte ao FixBot
      Comentar
    6. Tara Handle Replacement: passo 6, imagem 1 %32 Tara Handle Replacement: passo 6, imagem 2 %32
      • Unscrew the pump handle from the top of the riser main.
      • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
      Pergunte ao FixBot
      Comentar
    7. Tara Handle Replacement: passo 7, imagem 1 %32 Tara Handle Replacement: passo 7, imagem 2 %32
      • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
      Pergunte ao FixBot
      Comentar
Conclusão
Sam Goldheart
Membro desde: 10/18/12
477.842 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 48.981 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 530
