Introdução
If the battery will not hold any charge or if no power is going through to the device you will have to change the battery.
O que você precisa
Remove the rubber pad from the bottom of the device by using the nylon spudger to pry the glue holding it together. Then use the spudger to remove the rubber pad.
3 outras pessoas executaram este guia.
5 comentários
What is battery spec and how can i get one?
Mike
Does anyone know how to convert this to direct USB power or power adapter? I know that I can charge it using USB, but I think the battery in my unit is almost dead because it doesn’t last long. If I keep it plugged to USB while using it, it turns off after some time, again probably because of the bad battery.
I appreciate the information but in THIS case it is mot worth the expense and effort to refurbish a $25 unit. Thank again for the effort
