Ir para o conteúdo principal
Tagital T7X Screen/ Digitizer Replacement
O que você precisa
  1. Tagital T7X Screen/ Digitizer Replacement, Case: passo 1, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement, Case: passo 1, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement, Case: passo 1, imagem 3 %32
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Screen/ Digitizer Replacement, Battery: passo 2, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement, Battery: passo 2, imagem 2 %32
    • Follow the attached wires to the positive and negative connections.
  3. Tagital T7X Screen/ Digitizer Replacement: passo 3, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 3, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement: passo 3, imagem 3 %32
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the negative wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
    • Repeat this step for the positive wire.
  4. Tagital T7X Screen/ Digitizer Replacement: passo 4, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 4, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement: passo 4, imagem 3 %32
    • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
    • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
  5. Tagital T7X Screen/ Digitizer Replacement, Speaker: passo 5, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement, Speaker: passo 5, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement, Speaker: passo 5, imagem 3 %32
    • Remove the ribbon cable on the top left corner of the mother board.
    • Gently lift the black tape up to see the ribbon cable socket.
  6. Tagital T7X Screen/ Digitizer Replacement: passo 6, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 6, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement: passo 6, imagem 3 %32
    • Push both side buttons away from the socket by using a spudger.
  7. Tagital T7X Screen/ Digitizer Replacement: passo 7, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 7, imagem 2 %32
    • Gently pull the ribbon cable away from the socket.
    • Don't be afraid to use some force for this step.
  8. Tagital T7X Screen/ Digitizer Replacement: passo 8, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 8, imagem 2 %32
    • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
    • Repeat this step for the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
  9. Tagital T7X Screen/ Digitizer Replacement: passo 9, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 9, imagem 2 %32
    • Remove the speaker from the motherboard.
  10. Tagital T7X Screen/ Digitizer Replacement, Camera: passo 10, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement, Camera: passo 10, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement, Camera: passo 10, imagem 3 %32
    • Use a spudger to hold the cameras in place.
    • Gently pull the black tape away using your finger.
  11. Tagital T7X Screen/ Digitizer Replacement: passo 11, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 11, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement: passo 11, imagem 3 %32
    • Remove the ribbon cable from the motherboard.
    • Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
  12. Tagital T7X Screen/ Digitizer Replacement: passo 12, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 12, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement: passo 12, imagem 3 %32
    • Gently pull the ribbon cable away from the motherboard.
    • Don't be afraid to use some force to pull the ribbon cable.
  13. Tagital T7X Screen/ Digitizer Replacement, Motherboard: passo 13, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement, Motherboard: passo 13, imagem 2 %32
    • Next we will disconnect the digitizer ribbon cable from the motherboard.
    • Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
  14. Tagital T7X Screen/ Digitizer Replacement: passo 14, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 14, imagem 2 %32
    • Gently pull on the ribbon cable, separating it from the socket.
  15. Tagital T7X Screen/ Digitizer Replacement: passo 15, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement: passo 15, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement: passo 15, imagem 3 %32
    • Next, we will unscrew the three PH#0 screws anchoring the motherboard into the case.
    • You will need the Phillips Screw #0 to remove the screws of the motherboard.
    • Using the screwdriver, with the PH#0 attachment, carefully unscrew the screws of the motherboard in order to remove it from the device.
  16. Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: passo 16, imagem 1 %32 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: passo 16, imagem 2 %32 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: passo 16, imagem 3 %32
    • Insert a plastic opening tool where the screen connects with the front face of the case.
    • Use a spudger to keep the screen from falling back into the casing.
    • The screen will slide out once the connection has been nudged on three sides.
Conclusão
Garven Dabady
Membro desde: 02/10/16
370 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-1, Sullivan Spring 2016 Membro de USF Tampa, Team 2-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 685
