Ir para o conteúdo principal
Tagital T10 Battery Replacement
O que você precisa
    1. Tagital T10 Battery Replacement, Battery: passo 1, imagem 1 %32
      • Always make sure your device is completely powered off before performing repairs.
      • Remove the two 4 mm Phillips head screws at the top of the device.
      Pergunte ao FixBot
      Comentar
    2. Tagital T10 Battery Replacement: passo 2, imagem 1 %32
      • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside.
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
      Pergunte ao FixBot
      Comentar
    3. Tagital T10 Battery Replacement: passo 3, imagem 1 %32 Tagital T10 Battery Replacement: passo 3, imagem 2 %32
      • Locate the red and black wires that connect the battery to the motherboard.
      • Carefully peel away the tape that keeps the wires secured to the back of the display screen.
      Pergunte ao FixBot
      Comentar
    4. Tagital T10 Battery Replacement: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Be sure to use tweezers when near the soldering iron because it is hot.
      • Soften the old solder by heating it with the soldering tool, so that the wires can be removed with tweezers.
      Pergunte ao FixBot
      Comentar
    5. Tagital T10 Battery Replacement: passo 5, imagem 1 %32
      • Heat up the battery with the iOpener Heat tool in order to soften the adhesive that keeps the battery in place.
      • The iOpener Heat tool gets very hot, so be careful that you don't burn yourself.
      Pergunte ao FixBot
      Comentar
    6. Tagital T10 Battery Replacement: passo 6, imagem 1 %32 Tagital T10 Battery Replacement: passo 6, imagem 2 %32
      • Remove the battery from the device with the plastic opening tool.
      • It may be difficult to remove so try reheating the iOpener and don't be afraid to use a good amount of force.
      Pergunte ao FixBot
      Comentar
Conclusão
Cody D'Amato
Membro desde: 09/26/16
303 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-5, Eyestone Fall 2016 Membro de USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 1,321
