Ir para o conteúdo principal
Table Lamp Cord Replacement
O que você precisa
  1. Table Lamp Cord Replacement, Cord: passo 1, imagem 1 %32 Table Lamp Cord Replacement, Cord: passo 1, imagem 2 %32
    • Required materials: AAMP rewire kit, light bulb (not pictured), lamp shade (optional).
    • The AAMP lamp rewire kit should include a new cord, a socket shell, a socket interior and bottle adaptors. (Refer the second image to view the contents of the kit).
    Pergunte ao FixBot
    Comentar
  2. Table Lamp Cord Replacement: passo 2, imagem 1 %32
    • Caution! Before removing the lightbulb, ensure that the lamp is unplugged.
    • Cut the old lamp wire using scissors.
    • Remove the cord from the lamp.
    • Dispose the cord.
    Pergunte ao FixBot
    Comentar
  3. Table Lamp Cord Replacement: passo 3, imagem 1 %32 Table Lamp Cord Replacement: passo 3, imagem 2 %32
    • Thread the new wire through the hole on the bottom of the lamp. Pull it out through the top of the lamp base. (Refer the first image to get a better understanding.)
    • Place the old check ring on top of the lamp with the wire threaded through it. (Refer the second image to see the check ring.)
    Pergunte ao FixBot
    Comentar
  4. Table Lamp Cord Replacement: passo 4, imagem 1 %32 Table Lamp Cord Replacement: passo 4, imagem 2 %32
    • Place the lock nut at the end of the lamp nipple and turn it clockwise.
    • Thread the lock nut a quarter of the way through the lamp nipple.
    Pergunte ao FixBot
    Comentar
  5. Table Lamp Cord Replacement: passo 5, imagem 1 %32 Table Lamp Cord Replacement: passo 5, imagem 2 %32
    • Ensure that the lamp cord sticks through the top of the lamp base.
    • Insert the lamp nipple and the lock nut into the bottle, in such a way that one-fourth inch of the lamp nipple faces up.
    Pergunte ao FixBot
    Comentar
  6. Table Lamp Cord Replacement: passo 6, imagem 1 %32
    • Insert the socket in the lamp nipple.
    • Tighten the socket by turning it clockwise until it reaches the lock nut.
    Pergunte ao FixBot
    Comentar
  7. Table Lamp Cord Replacement: passo 7, imagem 1 %32
    • Pull either ends of the wire so that you have about 2-3 inches of the wire separated.
    Pergunte ao FixBot
    Comentar
  8. Table Lamp Cord Replacement: passo 8, imagem 1 %32
    • Tie an underwriter's knot in the two separated pieces of wire.
    • How to tie the knot: Form a loop using the first wire. Take the second wire and form a loop around the first. Pass the tail of the second wire through the loop of the first.
    Pergunte ao FixBot
    Comentar
  9. Table Lamp Cord Replacement: passo 9, imagem 1 %32
    • Check both the conductors at the end of the wire. Find the ribbed conductor and wrap it around the silver-colored screw. Connect the other conductor to the brass-colored screw.
    • Tighten both of the screws in a clockwise direction. Make sure the conductors are securely under the screw head.
    Pergunte ao FixBot
    Comentar
  10. Table Lamp Cord Replacement: passo 10, imagem 1 %32 Table Lamp Cord Replacement: passo 10, imagem 2 %32
    • Place the socket shell (with paper liner) over the socket interior. Snap it into correct position. Listen for clicks to make sure that the shell is locked properly.
    • The socket should snap together to form one piece.
    Pergunte ao FixBot
    Comentar
  11. Table Lamp Cord Replacement: passo 11, imagem 1 %32
    • Caution: Be sure that the rewired lamp is not plugged at this step.
    • Insert the new light bulb into the socket. Plug the cord and turn it on.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Aysha Vear
Membro desde: 11/04/15
195 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 60
Ao todo: 8,417
