Ir para o conteúdo principal
TRS-80 Color Computer Motherboard Replacement
O que você precisa
  1. TRS-80 Color Computer Motherboard Replacement, Outside Casing: passo 1, imagem 1 %32
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
    Pergunte ao FixBot
    Comentar
  2. TRS-80 Color Computer Motherboard Replacement: passo 2, imagem 1 %32 TRS-80 Color Computer Motherboard Replacement: passo 2, imagem 2 %32
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
    Pergunte ao FixBot
    Comentar
  3. TRS-80 Color Computer Motherboard Replacement, Keyboard: passo 3, imagem 1 %32 TRS-80 Color Computer Motherboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
    Pergunte ao FixBot
    Comentar
  4. TRS-80 Color Computer Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 TRS-80 Color Computer Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 TRS-80 Color Computer Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
    Pergunte ao FixBot
    Comentar
  5. TRS-80 Color Computer Motherboard Replacement: passo 5, imagem 1 %32 TRS-80 Color Computer Motherboard Replacement: passo 5, imagem 2 %32 TRS-80 Color Computer Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Andrew
Membro desde: 01/23/11
530 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-24, Maness Winter 2011 Membro de Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 46
Ao todo: 4,561
