Ir para o conteúdo principal
TRS-80 Color Computer Keyboard Replacement
O que você precisa
  1. TRS-80 Color Computer Keyboard Replacement, Outside Casing: passo 1, imagem 1 %32
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
    Pergunte ao FixBot
    Comentar
  2. TRS-80 Color Computer Keyboard Replacement: passo 2, imagem 1 %32 TRS-80 Color Computer Keyboard Replacement: passo 2, imagem 2 %32
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
    Pergunte ao FixBot
    Comentar
  3. TRS-80 Color Computer Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 TRS-80 Color Computer Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 11-24, Maness Winter 2011 Membro de Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Membros
Autoria de 10 guias
1Comentário do guia
This only applies for Color Computers issued after the CoCo 1 F Board (as shown) RS catalog 26-3004 and subsequent models (CoCo 2 & 3). Early editions of the CoCo 1 had not a mylar ribbon cable like this but a heavier ribbon composed of actual wires, the connector they went into was also built for this type of ribbon. The keyboards on each category of connecting ribbon are sadly not interchangeable.
Rogelio Perea - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 45
Ao todo: 3,883
