Ir para o conteúdo principal
TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement
O que você precisa
  1. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: passo 1, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: passo 1, imagem 2 %32
    • Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 2, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommended that you start from a corner and run the tool along the edge
  3. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 3, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 3, imagem 2 %32
    • Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
    • Remove the bracket.
  4. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 4, imagem 1 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 4, imagem 2 %32 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: passo 4, imagem 3 %32
    • Unplug the power cable harness from the motherboard.
    • Lift the power jack out of its slot in the top right corner.
    • Remove the cable.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Thanks for this. Great help in sorting out my laptop.
Jack - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 576
