Ir para o conteúdo principal
TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
O que você precisa
  1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: passo 1, imagem 2 %32
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 2, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 2, imagem 2 %32
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 3, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 3, imagem 2 %32
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 4, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 4, imagem 2 %32
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 5, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 5, imagem 2 %32
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 6, imagem 1 %32 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 6, imagem 2 %32 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 6, imagem 3 %32
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
Conclusão
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 346
