Ir para o conteúdo principal
TMY V08 Speaker Replacement
O que você precisa
  1. TMY V08 Speaker Replacement, Top Panel: passo 1, imagem 1 %32 TMY V08 Speaker Replacement, Top Panel: passo 1, imagem 2 %32 TMY V08 Speaker Replacement, Top Panel: passo 1, imagem 3 %32
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Speaker Replacement: passo 2, imagem 1 %32 TMY V08 Speaker Replacement: passo 2, imagem 2 %32 TMY V08 Speaker Replacement: passo 2, imagem 3 %32
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Speaker Replacement, Speaker: passo 3, imagem 1 %32 TMY V08 Speaker Replacement, Speaker: passo 3, imagem 2 %32 TMY V08 Speaker Replacement, Speaker: passo 3, imagem 3 %32
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Speaker Replacement: passo 4, imagem 1 %32 TMY V08 Speaker Replacement: passo 4, imagem 2 %32
    • Rotate the projector counterclockwise 90 degrees
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Speaker Replacement: passo 5, imagem 1 %32 TMY V08 Speaker Replacement: passo 5, imagem 2 %32 TMY V08 Speaker Replacement: passo 5, imagem 3 %32
    • Rotate the projector counterclockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Speaker Replacement: passo 6, imagem 1 %32 TMY V08 Speaker Replacement: passo 6, imagem 2 %32 TMY V08 Speaker Replacement: passo 6, imagem 3 %32
    • Remove the five 7.3 mm screws from the black cover using a Phillips #1 screwdriver.
    • Take off the right black cover, exposing the speaker.
  7. TMY V08 Speaker Replacement: passo 7, imagem 1 %32 TMY V08 Speaker Replacement: passo 7, imagem 2 %32
    • Grasp the speaker firmly and lift up to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 90
